GS BT Module
Hello I purchased the GS for my phantom 2. I was wondering if I can use the BT module with my A2 FC for my S900?
OI Photography said:
The A2 has its own BTU built in to the LED module, no need for an external one :)
So do you need the GS BT module to using GS with the A2 or use the built in one?
The BTU on the Groundstation is used with the ground end of the Data Link, so your iPad can connect to that...not on the aircraft end. Otherwise you'd only have an iPad connection until you flew 40ft away.
So essential I have two crafts with ground station on them? Except with the A2 I am able to connect via BT using just my phone or ipad to make FC adjustments.
You will have the groundstation on whatever aircraft you install the 2.4GHz Data Link on. The BTU/LED on the A2 is just for connecting with that Assistant app to adjust settings.
Thanks for clearing that up.
DonT
