GPS
How high off the ground does it need to be for the gps to kick in. I get it up 3-5ft and it still wants to drift?
Re: GPS
I can't get the GPS hold to work. I calibrated the compass and have both switches up. I can switch from gps to Atti and I can't tell the difference. Both seem very drifty. Any advice?
Re: GPS
Is it drifting in a straight line in the direction of the wind or is it circling? Does it stop after moving it or keep going in the direction it was travelling?
With GPS it may circle a bit (toilet bowl effect) but should settle down. Atti will drift in a straight line with the wind and also continue drifting when you let go of the sticks.
Connect to the NAZA assistant software and check that your switches are working. You might want to do an advanced calibration and then compass calibration before you fly it again.
Re: GPS
It seems to drift in all directions. I keeping it low 6-8f max and it feels very unstable in GPS. I'll try the advanced calibration.
Re: GPS
Ok. No matter what range I get it 3'-10' it continues to drift weather in gps or Atti mode.
Re: GPS
in gps it can still drift as much as a few feet side to side.
Re: GPS
Am I correct. If you have it in GPS mode it should hover within a 3' or so area?
Re: GPS
It's more than a few. I can go left to right and it will continue to drift and pretty much does the same in Atti mode.
Re: GPS
I said meters, not feet. A meter equals about 39 inches. Make sure both the S1 and S2 switches are in the UP position. Unless the switch settings have been changed the GPS system should function correctly.
Re: GPS
So like what ive seen on vids etc.... It won't just sit there and hover within a 5-6' area? Also I've noticed while flying I'll get a series of slow blinking green and a blinking red will pop in there so often what's that mean? I looked and couldn't figure that out?
Re: GPS
From what I see. 4-5 green then 1 red. It may go another 10-15 green blinks then another red. I tried to pay more attention but the GPS hold isn't working right as in drifting all over the place. Seems to drift more to the right. I do have the prop guards and string as I'm not that confident and glad I had them today!
Re: GPS
Yes from what I can tell all green at take off. In start up I get some yellow blinks from what I remember??? The red starts from what I see in flight and continues to blink here and there until I stop.
Re: GPS
if the GPS does not see enough satellites, it will automatically switch to ATTI mode. If you get occasional red lights, then you have less than six satellites. Have you tried launching in other areas?
If you have crashed hard, it may have broken the GPS antenna inside.
Re: GPS
No hard crashes as i only have been 5-8' in the air and using the prop guards
Re: GPS
Sometimes when I first start flying the quad will drift quite a bit maybe 10' from one side to another. So I fly around slowly, raising up to maybe 40' or 50' off the ground and flying back and forth, then I bring it back in close to me and it has always settled down and will hover just fine. Try that and let me know if it helps. It seems that after going through that process I do not have to do it again. The next battery and when I take off it hovers fine. Just happens to me at the first take off.
Re: GPS
It seems to be coming down to; not getting far enough away from you to establish actual GPS coordinates, 40-50 feet above and out the same distance, magnetic interference, (any cell phone towers near you), or switchs not in the correct position. The other option may be that you are losing a satalite lock after take off. What are the wind conditions during the flight? If GPS lock is established, the quad will attempt to maintain a horizontal hold in about a 4-10 foot radius. Otherwise, there may be a larger horizontal shift. If GPS lock is established and the winds are strong, the quad will return to the position before the winds moved it.
Re: GPS
heres my start off sequence is it correct?
starts of with a series of 1 green blink and 3 yellow blinks, repeats about 3-4 times
then a series of rapid flashing green lights about 10 times
then 1 green 2 yellow
then 1 green 1 yellow and a series of rapid green lights 8-10 times
finally a green flash every 2-3 seconds
Michello
