This a is pretty simple question but I don't see an answer in the manual. If I switch from GPS ON (S1 at position 1 up) to GPS OFF (1st position 2 middle), will GPS work if I switch back to GPS ON? Thinking I might get smoother video with GPS off.
grochester said:This a is pretty simple question but I don't see an answer in the manual. If I switch from GPS ON (S1 at position 1 up) to GPS OFF (1st position 2 middle), will GPS work if I switch back to GPS ON? Thinking I might get smoother video with GPS off.
themosttoys said:grochester said:This a is pretty simple question but I don't see an answer in the manual. If I switch from GPS ON (S1 at position 1 up) to GPS OFF (1st position 2 middle), will GPS work if I switch back to GPS ON? Thinking I might get smoother video with GPS off.
Yes, you can switch between GPS and ATTI mode with no problems (GPS mode will come back on.) With practice, ATTI mode will produce better video results (just be careful of wind and momentum.)
