GPS Tracker TK-102 interfering with video feed
Anyone having problems with there TK-102 interfering with their FPV feed? I'm getting green and pixelated video no matter where I place it. I have a Vision + and using H2O as the carrier. The problem goes away when I completely remove the TK-102. Not sure what the cause is. Is it the band that H2O is using that is interfering with my wifi channel? Can the wifi channel be changed? Any advice?
Not using the magnetic back. Mine is the TK-102-2 also. I'm using H2O as my carrier, which is AT&T's 850mhz band. The video feed for the range extender is between 2412-2462MHz so I can't figure way it's interfering. What carriers are you using? Thinking about buying a T-Mobile sim because they are at 1900 Mhz if that would make a difference. Stumped?
