Today I was flying and pushed my home to land and my drone came over my house and then went back up and took off to the next block over and crashed, can someone explain what happened or did I do something wrong in my settings.
Someone might be able to explain it if they can see your recorded flight data.Today I was flying and pushed my home to land and my drone came over my house and then went back up and took off to the next block over and crashed, can someone explain what happened or did I do something wrong in my settings.
That suggestion would not cause the incident as described.To answer you question did you do something wrong, the answer most likely is that your drone most likely experienced some type of Manetic interference and caused the drone to exit GPS and enter into Atti Mode
