- Joined
- Dec 2, 2016
- Messages
- 185
- Reaction score
- 30
- Age
- 68
Can anyone recommend a basic GPS instrument that would be good for making ground control points to be used with mapping software?
There's a lot more to UAV mapping then just taking pictures, so I'll try to give you a brief overview. If you want to get an accurate and precise topographic map, 3D point cloud, or orthophoto, you're going to need to know where exactly in the world your model is being established. You can do that by knowing exactly where your ground control points (GCPs) are, or exactly where your UAV is when it took the picture (along with the pitch, roll, and yaw of the craft). GCPs are aerial targets that are then referenced in the software to nail down where things are in the real world. The precise UAV location data is processed and can be reasonably good, but is always improved with GCPs, although not nearly as many are needed. Once you've built your 3D model from the photos, the other products can be generated. Without precise data from GCPs or a highly accurate location for the UAV, you're just generating pretty pictures to look at. Does that answer your question?Please tell me the primary differences
I guess I'm lost as to what you're asking. We are currently using painted 5-gallon bucket lids and they work well, or at least up until about 300' AGL (with the P4P). For elevation check shots we may spray paint an X on the ground, since we're primarily interested in checking the vertical data. You can use anything that you can easily find in the air photos, though, including cracks in the pavement, parking stripes, a tree stump (probably not the best, though), etc.I was referring to actual spots on the ground
