Got the shakes
That looks to me like regular prop turbulence, this happens if you drop straight down into the air you've disturbed. Only way around it is to descend while moving forward or in a circle to clear the bad air, the Phantom can get pretty rough with a fast descent and you want to avoid this as its also shaking the frame to bits while doing this. Some props are worse then others but the more lift a prop gives the more it disturbs the air below so you need to avoid flying through that if you can.
jeetbuzz360
