GOPro pointed at ground after 3.16 upgrade
Oh why did I upgrade to 3.16 ?
If I power on the Phantom and leave RC off, the camera is pointed forward.
A few seconds after turning on the RC the camera rotates 90 degrees and is pointed at the ground.
Moving the Phantom the Zenmuse appears to be working however still pointed at the ground.
Pointers on how to calibrate if possible ?
Standard RC
DJI says, "Make sure to reconfigure all parameters in the assistant software after upgrading firmware, since V3.16 upgrade will reset all parameters."
You need to give all the details of your setup. Did you replace the PDB? Did you install the control lever on the stock RC? Did you run the NAZAM Assistant?
tom sauter
