Gimble spinning
My p3 had a minor crash from about 4m high onto soft grass and landed upside and down broke 2 rotors . My camera has no marks or scratches it still films and focus fine but the gimble is spinning all around any ideas of what could be up a lose wire or plug or who knows
See if there is any damage to the clip in cable. Pull out and inspect and make sure none are dislodged.
If that fails, check the gimbal and make sure its not bent or if the hex screw near the top (opp side of flex cable) has come loose. This needs to be tight and against the flat side of the D shaft.
Reactions: Debner666
