Gimbal
Hi I have problems with my Gimball to Phantom three standard picture works but not and the motors I have a faint buzzing sound from the motors I have changed the cables to gimbal are there more who have the same problem? Is there a wiring diagram i can look at? With kind regards Henrik
Welcome,
Um if you have a live screen view and you can move cam up and down with remote it sounds like it's ok,, motors not start could be couple things,,are you trying to start corect,dumb question but does happen,both sticks inside down,?
Are the gimble motors hot? Did you use DJI OEM replacement cables. Aftermarket don’t work usually. Any crashes or hard landings?
Hi i use China cable i have my 2nd cable and it is the same problem gimbal gyroscope error
