Gimbal yaw problem - P3SE
Milano, Italy
Hi guys,
Phantom 3SE (I’ve wrote 4k because SE is not in the list)
I realized that the cam is not aligned with the "nose" of the drone.
This happens both in flight and on the ground with engines switched on or off.
I calibrated the gimbal but it remained the same.
No crash or other problem.
The DJI GO app (version 3.1.18 modified for fly in FCC) says Gimbal disconnected but camera works, records and gimbal move normally.
In the picture you understand well the problem.
What can I do?
thanks
Vale
Hi @Vale,
I don't have the answer, but in the 2 years that I've been lurking here, I have seen numerous threads regarding the issue you are experiencing.
Did you do a search?
Hi @Vale,
Hi, thanks for your reply.
I’ve done a search but most of problems I’ve found are about P4.
I couldn’t understand if is a software problem or an hardware problem.
The only similar to mine is this (but much more accentuated) Professional - P3P Camera off center
Do i really need to change the yaw motor? [emoji33]
apktuti
