Hi all,
I have a P3A (in my possession) and I have an issue with the gimbal. I don't know the history of the aircraft but looks pretty rough.
Anyway, the issue is that the camera is tilting to the left (left side down). Everything works though, I get an image on the tablet, I can tilt the cam up and down, SD card recognised etc.
The weird thing is, I can do a gimbal calibration (twice needed) to fix the problem and the cam is pointing straight again. I turn the aircraft off and it stays (most times) straight, but when I turn it on again, the camera goes back to the same spot, tilted to the left (about 45 degree). At that point I can do a gimbal calibration again (2 times will bring it back straight), and it will fix it, until the next time I power the aircraft off and on again.
I don't think it's a cable as I am able to temp fix it with 2 gimbal calibrations.
Anyone had this issue before? Any ideas?
