So here's a variation of that. My P3 Pro all of a sudden is exhibiting the jerky gimbal for no reason I can determine. See attached video. I recently recalibrated the IMU cold and that worked great to correct the slightly slanted gimbal I had been experiencing. I fired it up after all that everything was right. I put the P3 away for a few weeks, and took it out today to show a new P3 friend how to fly his. When I fired up mine, the gimbal went nuts and gave me the "gimbal motor overload" message. I rebooted several time and got the same thing. All firmware on controller and P3 is the latest and it has had no impact damage at all. All three axis of the gimbal rotate freely and with no rubbing or grinding or hesitation at all. On each restart however, the same behavior is exhibited. Any thoughts on anything else I could try? I though I'd reinstall the latest firmware, but I couldn't get the red and green blinking, beeping. Perhaps because it was already up to date. The GO app tells me all software is up to date. I did take off for a short hop to make sure the P3 could fly fine and it functioned normally. I landed immediately so as not to jeopardize any gimbal components that were getting worn or overheated. Thanks for any advice. I'll send it in if I need to, but can't understand why this would come out of the blue. Would re-calibrating IMU do anything, even if the IMC check said all was fine?
