Gimbal Motor Overload
Recently, I purchased a crashed P4P from a online local auction and rebuild the gimbal by replacing the yaw arm and flex ribbon cable. However, the gimbal will startup fine until it will indicate "gimbal motor overload" and gimbal start to twitch with a twitchy visual view. I recalibrated with the same results of gimbal overload and checked flex ribbon cable for obstruction. Any helpful advise will be helpful in resolving this issue. Thanks!
Check mechanically if gimbal is able freely move in each from 3 axis up to edge position. Maybe some of axis motors has to be changed.
The yaw motor sensors are damaged. I have a YouTube video on how to repair it. Do not just replace the yaw motor.
