Gimbal glitch
Hi guys, have the issue need your help: I've got 2nd Phantom with H3-3D. Sometimes, while flying I have the same problem with gimbal as on the video below (on 3:49):
http://www.youtube.com/watch?v=f0SBieZzvYo
The only solution I've found was firmware update, but as I understood to update gimbal firmware I have to update main controller firmware (It's 1,08 at the moment and I can update to 3.04). I'm not sure that it's a righ move, because there are a lot of negative feedback regarding 3.04 MC firmware version. So the questions are following:
- Are there any different ways to solve the gimbal glitch?
- Is it possible to update gimbal firmware without updating MC firmware?
- Is 3.04 mc firmware really bad, or you recomend to update?
Thanks a lot
Hello,
I am at work so I can not see your Video. I was at 3.04 and went back to 1.08 and installed Frsky x6r RX. I noticed that without the props spining, I give it yaw or ruter the Gopro h3-3d turns left and right, I then went on a test flight......I flew at 5 to 6 feet high and could fly it how it did befor upgrade until I gave it ruter input...It seems once you turn past 90 degrees the phantom2 / h3-3d takes over and tries to bring it back to a foward direction?
I am using the Sbus only and when I get a chance I will put the gimbal back on x1 of the Naza......I will do anything to Not Upgrade to 3.04
tom sauter
