gimbal camera separation
North central Illinois
Is there any fix to this situation or do I need a new gimbal/camera unit? The camera separated from the gimbal in a hard crash, breaking the plastic mount and the ribbons. The quad still flies. I see the ribbons are plugged in, but I'm not sure what's involved in replacing the broken camera to gimbal mounting ring. Also, will a Phantom 3 Advanced gimbal/camera work on a P3Pro body, if I do need a new set up?
That's a pretty easy fix , you can do it probably, I did mine , new ribbon and arm , roll arm is what is broke on yours . About a hundred for parts
Brand new gimbal / cam costs $275. So estimate repair cost before buying anything.
Where do you get a g/c for 275 new ?
I did the same repair. Search youtube for: irepairmd and DJI Phantom 3 broken gimbal repair
Not for a pro I don't think unless you work there or something
Op wanted to repair P3A
No he asked about a p3p hence the persons name"p3pfler
It's a Pro. I was just curious if an Advanced gimbal/camera would work on a Pro body. I found that 2.7 k would be sufficient for my use. I'm going to try just the roll arm and cables first.
jorge sanchez
