Getting 00015006][19 00][00] v255.255.255.254 -> v1.0.8.96
Hi,
I have P3P, I got
“[00015006][19 00][00] v255.255.255.254 -> v1.0.8.96”
I have tried to downgrade from 11.2 to 1.7.6 but the same issue, the model didn’t update.
Any advice
I've seen a few of these "v255.255.255.254" version numbers, usually in FPGA module. Upgrading the FW leaves these modules intact, so at first I though this is a way DJI uses to avoid upgrading the module (ie. if a component needs a work-around in firmware, the current FW version is set so high to always report that it's newer).
But now I'm not that sure anymore. This may be just a common glitch which happens in the FPGA chip.
What's your downgrade log?
I looked into the logs and found that happened when i was downgrading the P3P from 1.8 to 1.7
But I am not sure it will impact the gimbal.
hcashmore11
