FPVLR mod should I be concerned?
I'm working on doing my FPVLR mod and while cleaning off the glue around the 5.8 connector I noticed that it looked like I cut the ring on the u.fl connector (see image). Should I be concerned? The antenna wire for the mod connected to it just fine but I'm not sure if it will cause an issue with transmission.
Shouldn't be a big deal. The middle pin is more important and as long as the pigtail connects securely to the plug, you should be alright.
PuppaDD
