FPV trouble shooting
FPV and iOSD mini problem. When I fire up Phantom II and on-screen display I see the iOSD info, I fire up the GOPro and get video to the display terminal. I move a couple feet away and lose the video and the IOSD info.
The antennas are on. One clover and one panel on the display.
One clover hanging from phantom and two wire antennas.
Did work previous not sure what has changed.
If I am with in a foot of phantom it works.
2 feet snow and flickering picture and on screen nav info
Beyond that all goes dark
Any suggestions would be helpful
Thank you
Sounds like antenna problems to me. Video transmission will show like this even if you have no antennas on the receiver. So I would check the antennas are properly screwed on tight and the fittings are correct type. Did you get distance before?
Sent from Samsung S4 via Tapatalk
have you ever powered on the Phantom with no antenna attached to the transmitter? that can "burn out" the transmitter and you'd be left with basically no output power / range.
if not, like Irish said it sounds like some sort of antenna issue
dlr11164
