FPV for the FC40
Discussion in 'Phantom FC40 Discussion' started by deltamike, Sep 29, 2014.
  1. deltamike
    Shropshire (UK)
    Hi,
    Any techs out there, please have a gander at the specs of the following.
    http://www.banggood.com/DIY-5_8G-200mW- ... 47633.html
    It looks okay but before I consider buying it are there any pitfalls that you can see. Its 5.8 Ghz that might interfere with the control frequency, but any thoughts would be appreciated.
    Pete
  2. dtviewer
    I believe with the FC40 you need to look at a 2.4 FPV set up.
  3. pert
    Bermuda
    and make sure if your getting goggles they will work on 2.4,
  4. ericymx
    Montreal, Canada
    you should check this out, I think this is what I am going for.
    http://hobbywireless.com/24-ghz-systems ... -p-20.html
    http://hobbywireless.com/portable-video ... -1008.html
    http://hobbywireless.com/mini-fpv-camer ... p-945.html
    I Have order the Turnigy Mobius 2-Axis Gimbal and should receive it within a few days. I want to order the mobius cam also, but I will try to use the gimbal with the fc40 cam for now.
    I want to use the mini fpv cam so I cand set the mobius on Time Lapse photo shooting.
    I think this is the way to go.
    Eric
  5. deltamike
    Shropshire (UK)
    Thanks Eric.
    Keep me up to date of how you are getting on please.
  6. deltamike
    Shropshire (UK)
    Hi DT.
    I quite agree, but if the transmitter and a/c keep swopping within the 5.8 channel would the FPV link REALLY interfere if it were on a fixed narrow band frequency- if you see what I mean.
    I don't know enough and have not got the knowledge to answer that question, and I am hoping a tech will answer this one.
    Pete
  7. lostkiwi
    UK
    The question is do you really want to risk it?
    DJI moved the FC40 up to 5.8GHz for a reason when they attached a 2.4GHz camera.
  8. deltamike
    Shropshire (UK)
    No - you are right - I will not chance it. Looks a nice bit of kit for the price too. Shame it isn't on 2.4
    Light bridge is good but for £800 odd its a bit pricey.
  9. darwin-t
    I got a 400 mw 2.4 Ghz video transmitter and matching receiver and it works quite well. I did buy a higher gain antenna for the receiver, it was less than 10 bucks at Amazon.
    I also got a backup monitor made for use in a car for the monitor. It has a 7" screen and it was well under $30
  10. ericymx
    Montreal, Canada
    I finally went with a digital 2.4Ghz 1000mW Tx/Rx
    http://www.hobbyking.com/hobbyking/stor ... _NTSC.html
    It's a bit heavy but works great I also bought a 7in screen.
    I use the camera now but will connect my mobius camera eventually.
    I just finalize the set up of the Tarot Mobius gimbal and it works great.
    [​IMG]
  11. motchjv
    I have used the Boscam 5.8G 200MW and 500MW video transmitter in a 5.8G FC40 without any problems. I think modern transmitters use much narrower bands and band switching with should prevent any interference problems.
    Chers
    John
Similar Threads - FPV FC40 Forum Date
Fc40 fpv Phantom FC40 Discussion Apr 24, 2016
Can I use basic 5.8 fpv setup with fc40? Phantom FC40 Discussion Sep 30, 2015
SOLD ! PHANTOM FC40 with extras! 300£ FPV! Hard case! Gimbal! Classifieds Aug 31, 2015
HELP!!! FC40 fpv info Phantom FC40 Discussion Jun 21, 2015
cheapest path to FPV on the FC40 Phantom FC40 Discussion May 3, 2015
