FPV Booster App DOUBLE Vision+ FPV Range
Re: Software Boosted Vision+ DOUBLE FPV Range
DBS said:
Wait did I miss something? What about Android? How do we sign up to download an Android beta to test or whatever :ugeek:
Based on the previous vote, there are more P2V+ iOS pilots than Android. Thus we start iOS beta testing first, and Android beta will be coming afterward.
Tony :
我的H3-3D雲台送修回來了,兩台3D大團圓 :lol:
希望能藉由你的軟體功放加持給P2V+ :twisted:
我希望P2V+與P2 飛行距離大PK :lol:
Do you think this app works with vision too? Same wifi chip doesn't it? :roll:
LMC said:
Tony :
Jason,
Both of your P2 and P2V+ are looking in good shape. Your P2V+ 5.8G antenna seems not taped along the landing skid. Any reason of not taping it?
PVFlyer said:
LMC said:
Tony :
Jason,
聽說這樣的收訊比較好,但我會找一天線來改裝! :lol:
LMC said:
PVFlyer said:
LMC said:
Tony :
Jason,
聽說這樣的收訊比較好,但我會找一條天線來改裝! :lol:
今天收到三個天線,還差一個2.4G的四葉草天線 :twisted:
等你的軟體功放一起加上去應該更好玩 :lol:
Wow! Your FPVLR antennas look awesome!
I suggest to keep your Vision+ as stock, and test the booster first. Then you may further test again after these antenna mods.
I expect the booster will increase 50-100% FPV range in rural area with/without antenna mod, but unsure about in urban area due to unknown noise level.
OK!
我這些天線都是模組化,可以隨時裝上去與拆下來 :lol:
不過!
一般普通正常的給別人測試,我可以測試爆改過得也不錯啊 :lol: :lol: :lol:
FPVLR said:
Hi,
how funny to see those high gain antennas. I thought you were using those for analog video transmission at 5.8 GHz,
the 12 turs is very directional so I can get between 15 and 20km with 5.8 ghz analog video transmitters, but with 30 degrees beamwidth you will have a hard time aiming it if you are flying a quadcopter, that is why I don't suggest those for phantom vision,
you 'd have to point exactly at the model. Also the range would just be much further than needed on a VIsion since you only need 5 or 6km of RC control range, there is no point in using such a narrow beamwidth and having 10-15km control range, but if you don't aim precisely you can lose control range even at 200 meters...
14db的小平板我也有啦!
P2V has the same Atheros Wifi chipset as Vision+. The similar approach should be applicable for P2V. However, the overlay protocol built on-the-top of 802.11 is very different between P2V and Vision+. Thus, it may need a complete different software configuration and protocol hack for P2V.
Let me get this booster done for Vision+ first. I will then come back to P2V afterward.
wow sounds good id be up for beta testing, now how do u pm some 1 lol
FPVLR said:
are you guys heat testing after the mod?
You need to be careful as not to lower the reliability of the system, which might need more cooling when the rf output is increased.
We did multiple heat tests with various TX power and protocol hacks, and some tested TX power were way higher than required. There is no notable temperature increase in all our tests, though the un-boosted Wifi module is fairly warm/hot anyway.
For those beta testers, you may install the beta on your iDevice with Safari browser at https://dl.dropboxusercontent.com/u/1830957/vision-plus/index.html. You will then be redirected to a page with a single link called "Install!", simply click the link to install the beta.
How it works:
1. Turn on both of your Phantom 2 Vision+ aircraft and Range Extender as usual;
2. Connect your iDevice to Wi-Fi network of the Range Extender;
3. Open V+ Booster app, and tap "Boost up!" button;
4. Open DJI VISION app and happy flying;
Feel free to let me know if any questions or issues.
How it works:
感謝 Tony,我先在室內測試用Nexus7觀察軟體功放使用前後之間的變化 :P
How it works:
awesomeness..just installed. will report back.
Holy crap this is awesome. thanks man..i have never flown this far with full FPV! 3300 ft!
PVFlyer said:
For the beta testing, can you test the same/similar flight path and share your test results including the following information.
1. Preview Quality (avoid using 640x480 30fps);
2. Rural, sub-urban or urban area;
3. Un-boosted FPV range;
4. Boosted FPV range;
What's wrong with flying at 640x480 30fps?
Lucas_rc_pilot
