For Sale: E300 Motor Pairs CW & CCW
2 Brand New, never opened E300 motor pairs (CW and CCW) for your Phantom 1, Phantom 2, F450 or F550 quads. Asking only $30 per pair, I have 2 pairs (one of each type per pair). These motors will provide better performance, longer flight times and smoother hovering than the standard motors.
Drop-in replacement for the following:
- Phantom 1
- Phantom FC40
- Phantom 2 / Vision
- F450
- F550
DJI E300 Motor Details:
The DJI E300 motor is a replacement motor for the E300 Tuned Propulsion system. The E300 Motor & ESC's are the first power solution designed for multi-rotor use, the higher thrust to weight ratio from the E300 system increases the reliability, stability and agility of flight through enhanced aerodynamics and efficiency from the motor and propeller combination.
The E300 motors are designed to work with the Tuned Propulsion system and the recomended propeller to use is the 9.4 x 4.3 with the E300 motors which deliver an average of 20-25% improvement over the 8 x 4.5 propellers without the need for an increase in motor size. The higher lift generated from the new profile propeller means that payloads can be increased without the need to upgrade the system.
PM me if you are interested in this GREAT deal!
hcashmore11
