That depends. If you lose GPS which is likely under a bridge, the VPS will attempt to maintain altitude, assuming you are within a certain distance from the base of the bridge. Personally, I would switch to ATTI for that. Once past, then back to GPS.Yesterday I tried flying under a bridge and I noticed the aircraft drop about 5' at a rapid rate.
Yep. VPS does not play well with water. If you turn the VPS off before the flight it will be smoother, but all manual.scared the crap out of me because I was over water.
Absolutely, if you are proficient in ATTI mode. Again, only the barometer will control your "hover" altitude.Do you think disabling the sensors would help?
