Flicker from top of the screen to the bottom
I think I just found out the problem. I think it's since I was looking at the video through the app it wasn't good quality but when I looked on my computer it looked fine
Reactions: MedicFL1
Might be related to the display device you are using.
Phantom 4. polar pro kit and lenses.
@MedicFL1 I am using an iPhone 7
In that case you should not have that artifact on your screen. I did but then changed to an Nvidia Shield K1 and only use it for that. No other apps running at the time.
Have you tried it with any other display device? (simply to rule out the IPhone which may have multiple apps running ).
@MedicFL1 I think it just has something with a low wuality video feed coming through the app. I have a video below that I took directly from the app and you can see a vertical line thing going down the screen every 5 seconds. Some parts of the video may be bad since I was getting weak image transmission but it always comes up with these lines in the app
akos9703
