Firmware upgrade failure - bricked P4P+
Thanks DJI for the latest round of ransomware.
#1
Now the aircraft (P4P+) fails to upgrade via Assistant, and it also fails to upgrade via DJI Go 4.
The upgrade appears to start, the firmware is downloaded and "transmitted" to the P4P+ but the upgrade process hangs somewhere between 7% and 24% completed when "updating". Any suggestions on how to load this f/w or at least debug the process?
#2
Furthermore the aircraft is reporting "Aircraft Encoder Error(0X20)"
and
#3
The camera video stream shows "not connected" but all other controls appear to be functional.
Searching this and other forums has not uncovered a cause or solution yet.
Contact DJI... You are still under warranty. You drone needs repair. If the firmware is corrupted. Only a repair or replacement can be done.
Correct. I had the same issue and they can flash the firmware right into the bird :)
