P3 Firmware Firmware fail: [01886141][19 00] Firmware upgrade finish failed (step = 2, err = 0x08)
My phantom 3 pro is bricked! I have tried to upgrade more than 10 times... this err insist to apper as in the log. Someone could help me?
I tried to downgrade with debub and no success also...
I doubt anyone will give you any advice beyond what's here:
Firmware m1900 · mefistotelis/phantom-firmware-tools Wiki · GitHub
The flash memory on OFDM board is most likely damaged.
Hi i have the same log msg.
If i change the ofdm, my drone can revive?
Thanks
[00015635]========== remo-con disconnect. boot(15) ============
[00015707]Packet [C:\P3X_FW_V01.11.0020.bin] detected, card sn [0x5f6f0370].
[00015777]Packet upgrade start...
[00015847]Packet checking...
[00016047]Packet vlink 01.11.0020 <-> 01.11.0020.
[00016110]Record vlink 01.09.0060 <-> 01.08.0080 (flow = 0).
[00016178]Done.
[00016251]Version checking[1]...
[00028833][03 06][00] device not detected.
[00041405][03 05][00] device not detected.
[00041480][04 00][00] v1.48.0.0 -> v1.48.0.0
[00054063][11 00][00] device not detected.
[00056698][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00056772][11 01][00] v1.8.0.0 -> v2.0.0.33
[00057008][12 00][00] v1.11.0.0 -> v1.12.0.0 need upgrade.
[00057139][12 01][00] v1.11.0.0 -> v1.12.0.0 need upgrade.
[00057248][12 02][00] v1.11.0.0 -> v1.12.0.0 need upgrade.
[00057348][12 03][00] v1.11.0.0 -> v1.12.0.0 need upgrade.
[00057537][15 00][00] v1.1.2.0 -> v1.1.2.0
[00057648][17 00][00] v1.1.1.7 -> v1.1.1.7
[00057788][17 01][00] v1.0.2.7 -> v1.0.2.7
[00057868][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00057943][01 00][00] v1.32.5432 -> v1.32.5432
[00058011][01 01][00] v1.32.5432 -> v1.32.5432
[00058098][08 00][00] v0.13.0.7 -> v0.13.0.7
[00058308][09 00][00] v3.0.0.10 -> v4.1.0.0 need upgrade.
[00058377]Done.
[00060449]Waiting for user confirm...
[00070519]Timeout, start upgrade automatically.
[00070659]Firmware upgrading[1]...
[00070753][12 00] Firmware upgrade start...
[00129276][12 00] Firmware upgrade finished successfully.
[00129371][12 01] Firmware upgrade start...
[00193614][12 01] Firmware upgrade finished successfully.
[00193708][12 02] Firmware upgrade start...
[00255152][12 02] Firmware upgrade finished successfully.
[00255340][12 03] Firmware upgrade start...
[00313846][12 03] Firmware upgrade finished successfully.
[00317848][19 00] Firmware upgrade start...
[00349320][19 00] Firmware upgrade finish failed (step = 2, err = 0x08).
[00379561][09 00] Firmware upgrade start...
[00436878][09 00] Firmware upgrade finished successfully.
[00436954]Done.
[00437021]Version checking[2]...
[00449589][03 06][00] device not detected.
[00462166][03 05][00] device not detected.
[00462239][04 00][00] v1.48.0.0 -> v1.48.0.0
[00467380][11 00][00] v1.8.0.0 -> v1.8.0.0
[00467520][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00467587][11 01][00] v1.8.0.0 -> v2.0.0.33
[00467720][12 00][05] v1.12.0.0 -> v1.12.0.0
[00467830][12 01][05] v1.12.0.0 -> v1.12.0.0
[00468049][12 02][05] v1.12.0.0 -> v1.12.0.0
[00468175][12 03][05] v1.12.0.0 -> v1.12.0.0
[00468328][15 00][00] v1.1.2.0 -> v1.1.2.0
[00468426][17 00][00] v1.1.1.7 -> v1.1.1.7
[00468590][17 01][00] v1.0.2.7 -> v1.0.2.7
[00468685][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00468755][01 00][00] v1.32.5432 -> v1.32.5432
[00468829][01 01][00] v1.32.5432 -> v1.32.5432
[00468903][08 00][00] v0.13.0.7 -> v0.13.0.7
[00469007][09 00][05] v4.1.0.0 -> v4.1.0.0
[00469075]Done.
[00469147]Firmware upgrading[2]...
[00473119][19 00] Firmware upgrade start...
[00503803][19 00] Firmware upgrade finish failed (step = 2, err = 0x08).
[00533868]Done.
[00533945]Version checking[3]...
[00534044][03 06][00] v2.4.20.28 -> v2.4.20.50 need upgrade.
[00534144][03 05][00] v34.2.0.9 -> v34.2.0.9
[00534230][04 00][00] v1.48.0.0 -> v1.48.0.0
[00534364][11 00][00] v1.8.0.0 -> v1.8.0.0
[00534505][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00534580][11 01][00] v1.8.0.0 -> v2.0.0.33
[00534698][12 00][05] v1.12.0.0 -> v1.12.0.0
[00534825][12 01][05] v1.12.0.0 -> v1.12.0.0
[00534933][12 02][05] v1.12.0.0 -> v1.12.0.0
[00535044][12 03][05] v1.12.0.0 -> v1.12.0.0
[00535296][15 00][00] v1.1.2.0 -> v1.1.2.0
[00535432][17 00][00] v1.1.1.7 -> v1.1.1.7
[00535573][17 01][00] v1.0.2.7 -> v1.0.2.7
[00535669][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00535737][01 00][00] v1.32.5432 -> v1.32.5432
[00535807][01 01][00] v1.32.5432 -> v1.32.5432
[00535893][08 00][00] v0.13.0.7 -> v0.13.0.7
[00535989][09 00][05] v4.1.0.0 -> v4.1.0.0
[00536062]Done.
[00536132]Firmware upgrading[3]...
[00536505][03 06] Firmware upgrade start...
[00952059][03 06] Firmware upgrade finished successfully.
[00956060][19 00] Firmware upgrade start...
[00986747][19 00] Firmware upgrade finish failed (step = 2, err = 0x08).
[01016813]Done.
[01016882]Version checking[4]...
[01016999][03 06][05] v2.4.20.50 -> v2.4.20.50
[01017122][03 05][00] v34.2.0.9 -> v34.2.0.9
[01017201][04 00][00] v1.48.0.0 -> v1.48.0.0
[01017359][11 00][00] v1.8.0.0 -> v1.8.0.0
[01017518][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[01017590][11 01][00] v1.8.0.0 -> v2.0.0.33
[01017712][12 00][05] v1.12.0.0 -> v1.12.0.0
[01017839][12 01][05] v1.12.0.0 -> v1.12.0.0
[01017973][12 02][05] v1.12.0.0 -> v1.12.0.0
[01018099][12 03][05] v1.12.0.0 -> v1.12.0.0
[01018261][15 00][00] v1.1.2.0 -> v1.1.2.0
[01018408][17 00][00] v1.1.1.7 -> v1.1.1.7
[01018589][17 01][00] v1.0.2.7 -> v1.0.2.7
[01018673][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[01018747][01 00][00] v1.32.5432 -> v1.32.5432
[01018812][01 01][00] v1.32.5432 -> v1.32.5432
[01018903][08 00][00] v0.13.0.7 -> v0.13.0.7
[01018993][09 00][05] v4.1.0.0 -> v4.1.0.0
[01019067]Done.
[01019137]Firmware upgrading[4]...
[01023123][19 00] Firmware upgrade start...
[01053791][19 00] Firmware upgrade finish failed (step = 2, err = 0x08).
[01083857]Done.
[01083929]Version checking[5]...
[01084021][03 06][05] v2.4.20.50 -> v2.4.20.50
[01084141][03 05][00] v34.2.0.9 -> v34.2.0.9
[01084214][04 00][00] v1.48.0.0 -> v1.48.0.0
[01084401][11 00][00] v1.8.0.0 -> v1.8.0.0
[01084601][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[01084784][11 01][00] v1.8.0.0 -> v2.0.0.33
[01084907][12 00][05] v1.12.0.0 -> v1.12.0.0
[01085036][12 01][05] v1.12.0.0 -> v1.12.0.0
[01085162][12 02][05] v1.12.0.0 -> v1.12.0.0
[01085297][12 03][05] v1.12.0.0 -> v1.12.0.0
[01085469][15 00][00] v1.1.2.0 -> v1.1.2.0
[01085594][17 00][00] v1.1.1.7 -> v1.1.1.7
[01085731][17 01][00] v1.0.2.7 -> v1.0.2.7
[01085816][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[01085882][01 00][00] v1.32.5432 -> v1.32.5432
[01085957][01 01][00] v1.32.5432 -> v1.32.5432
[01086043][08 00][00] v0.13.0.7 -> v0.13.0.7
[01086137][09 00][05] v4.1.0.0 -> v4.1.0.0
[01086204]Done.
[01086278]Firmware upgrading[5]...
[01090272][19 00] Firmware upgrade start...
[01120954][19 00] Firmware upgrade finish failed (step = 2, err = 0x08).
[01151024]Done.
[01151090]Version checking[6]...
[01151206][03 06][05] v2.4.20.50 -> v2.4.20.50
[01151306][03 05][00] v34.2.0.9 -> v34.2.0.9
[01151407][04 00][00] v1.48.0.0 -> v1.48.0.0
[01151565][11 00][00] v1.8.0.0 -> v1.8.0.0
[01151708][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[01151777][11 01][00] v1.8.0.0 -> v2.0.0.33
[01151899][12 00][05] v1.12.0.0 -> v1.12.0.0
[01152025][12 01][05] v1.12.0.0 -> v1.12.0.0
[01152134][12 02][05] v1.12.0.0 -> v1.12.0.0
[01152259][12 03][05] v1.12.0.0 -> v1.12.0.0
[01152464][15 00][00] v1.1.2.0 -> v1.1.2.0
[01152595][17 00][00] v1.1.1.7 -> v1.1.1.7
[01152760][17 01][00] v1.0.2.7 -> v1.0.2.7
[01152860][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[01152931][01 00][00] v1.32.5432 -> v1.32.5432
[01153005][01 01][00] v1.32.5432 -> v1.32.5432
[01153093][08 00][00] v0.13.0.7 -> v0.13.0.7
[01153199][09 00][05] v4.1.0.0 -> v4.1.0.0
[01153267]Packet upgrade failed at firmware upgrade.
You did not shared anything about your symptoms.
From the update log, all the modules besides m1900 seem to be functional.
With available data, I'd say yes.
thanks for your answer.
my symptoms are, long beep when try to update firmware, with/without debug file in sdcard.
no sync with rc
i can affirm this ofdm is dead?
hcashmore11
