Firmware Beeps
Victoria BC
I just tried to install v.1.10.90 on my phantom 3 pro. I've had no issues updating in the past, but this time around after putting the .bin file on the micro sd and putting it into he drone and powering it up.... It didn't do any of the beeping patterns it usually did.
Eventually i powered it down, even though I was terrified to because I didn't want to shut it down during the updating process. But after I did, not only did it not work but it didn't make any of the noises or generate a text file with status update.
I followed the tutorial I normally do, but this time no beeps.
Thoughts?
Thanks!
Format the SD Card and try again?
There are quite a few posts of problems with 1.10.90. You might be better off that it didn't update and leave well enough alone. Unless you're having issues with your current FW. ??
peoplelogic
