Firmware 1.6 result
Hi all. I just update my firmware on P3P and this result like [emoji115]. This is normal or something wrong especially in last result that " firmware on sd card is identical to or older than the current firmware on the aircraft "
FYI : i just download and update my aircraft then my remote but why the statement like that. I never update or do something before in my P3P especially my remote. And this make me affraid to fly my P3P now [emoji33][emoji33][emoji33]
And after i change the batterai to a new batterai shown like this? So what i do next
Need help [emoji120]
Thx
You don't have a problem, your txt file is telling you your batteries were updated and because the bin file is on the SD card every time you turn the P3P on it will check the firmware. Go fly [emoji51]
Also make sure you do an IMU and compass calibration
Here's my story on the 1.6 upgrade.
was on 1.5 and started doing the upgrade for 1.6. Then I noticed it was stuck on the red LED for an abnormally long time. I gave it a few more minutes and then I stopped it. Checked the status and it said that it failed and to retry. I retried but it wouldnt upgrade as it was already on 1.6 ( You can see all these statuses below)
Then I decided to downgrade to 1.5 and reupgrade to 1.6 - success.
It was the first time I had this small issue and I've been upgrading since P2.
It's nothing major but just wanted to share - also I dont recommend stopping the upgrade process, its a risk with all electronics to stop them mid-upgrade . It was my call
Delete history success.
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
2014.01.01 00:00:12 ========== with paddle-disconnect ======
Packet: P3S_FW_V01.06.0040.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
Result: Abort.
Packet: P3S_FW_V01.05.0030.bin
Upgrading ...
Result: Success.
Upgrading ...
Result: Success.
I succes update my craft to 1.06 firmware but my remote won't update when i change the SD card to remote from aircraft. But i try to ON my P3P the overall status is normal but the version firmware aircraft and remote is different. Is it ok? Or i should downgrade my firmware first then upgrade to 1.06 again?
Jerry P
