- Joined
- Apr 14, 2015
- Messages
- 3,534
- Reaction score
- 2,041
- Age
- 49
Thats what i thought too RPH til this same thing happened to one of mine! Dont jinx yerselfYes, no indeed. ;-)
I have one of the trouble free drones. No issues.
RedHotPoker
RedHotPoker
I really don't see how a partially discharged battery could cause any of these incidents. If there is enough battery to take off, then all that would happen if the battery capacity drops in flight is the aircraft would go into a fail safe landing.
I believe that all of these "sudden power loss" complaints is the battery connector disconnecting for less than a millisecond. That's all it would take. Everything goes dark as the controller processor reboots, but the aircraft is falling out of control and hits the ground before the processor can restart. In my 3DR Hex the controller can be powered separately from the motors so that a momentary power loss to the motors would not cause a processor shutdown.
tcope.....regardless of the situation, I'm sorry you had to experience something you should not have had to.
No, once you switch on the battery by pressing two times, it comes out of discharge mode. And that's what happens when you start flying, battery is never in auto discharge mode.Yeah, I figure it is what it is. I enjoy flying so I should expect to have "stuff" happen. Thanks.
The more I read up on the subject the more I think it's a problem with the auto discharge. I would agree with others that it seems like the system (drone, app, whatever) reports the battery at a moderate level but then simply cuts it off. To really guess at it, I'd guess that it turns off thinking it's still supposed to be discharging and the only way to turn off this discharge mode is to put the battery on a charger.
I can't come up with any good reason why a battery with 61% charge just turns off. I've flown batteries with 40% charge (landed, turned off, made adjustments and then flown again) with no issues. I suspect I've even landed and turned off at 20% and then turned on and hovered in order to drain down to 8%. Never any issues.
The person who needs to be contacted privately about this matter,Of course there were words over it, they were not happy the info was leaked. But that is not the topic here. I just wanted to clarify what had happened. You can contact me privately if you have any other questions. Thanks.
You may call me RHP!! HaThats what i thought too RPH til this same thing happened to one of mine! Dont jinx yerself
Good examples, I am so glad I saw this thread now. 2 days ago I had flown to about 40% charge then taken a 15-20minute car ride and had planned to fly again for another 10% or so. It was cold weather as well. I am thankful I didn't, it could have definitely gone bad. You learn something new everyday.Check my other posts but it takes a lot to figure out a lithium battery's state of charge when it is partially charged, it is easy to track from full charge. To do this would compromise other features, you would have to stress the battery quite a bit before each flight which would lower everyone's flight time and add additional components and weight. When you work closely on a product somethings you neglect certain things as unlikely. Like to DJI they probably figure no one will try to fly on less than a full charge.
One way to fix it would be to just lock out flight when people start at less than 95% battery...but then you take decision making away from people.
For the people worried about flying on the same day and same battery I would not worry about touch and go and such. But personally if I flew down to 50% I would consider that battery done if moving to another location. My own rule is if I turn the phantom off, that battery is getting charged before I use it again....
An example is I was flying with my kids and one got attacked by fire ants. I landed and turned off the motors and then helped my son. After he was safe I powered up and flew as normal...
Another example is at 60% it looked like rain so I landed and went home. A few hours later it cleared up, but when I flew the second time I used the other fully charged battery...I would not use the partially discharged battery...
Be careful with these batteries....
I didn't dare to take that riskHave you allowed your batteries to go into auto discharge and then used them prior to charging up completely after installing the last firmware?
DeoxIT® Gold G100L, Squeeze Tube, 100% solution, 2 mL,
(Applications = 50 +/- drops, 0.04 ml/drop)
Part No. G100L-2C (2 mL)
DeoxIT® Gold G100L Mini-Brush Applicator, 100% solution, 1.6 mL
(Applications = 100 +/- brush strokes, 10mm long)
Part No. G100L-16BX (1.6 mL)
Then you are only repeating what _should_ be. You don't know that it's what is correct. You can repeat the manual all you want... real world experience is something different.I didn't dare to take that risk![]()
Hmm. I wonder if auto discharge activates when someone is flying? It seems that might be a big issue!So a battery should turn off in flight if it's at 60% charge?
Part of my issue was that the batteries were charged at 100%... it's just that the auto discharge had kicked in and I did not realize it. I do understand alokbhargava's point... if this _is_ an issue, then it should be addressed by DJI. It it comes down to the fact that someone should never start flying at less then 100% battery then a simply solution would be to either install a warning or lock out the flight. There are warnings for other things, such as lack of GPS signal.
