Okay, now I'm back with the drone and here's an exclusive summary of everything and all.
First of all the P3P was recovered in two different locations.
The battery was found at the open air observation deck of the tower, which has been closed to the public for at least 10 yrs due to some Darwin award fellas tossing down small items. I've been there when it was open and it's a nice place with fresh air. The battery is intact and it's still almost fully charged. This location is at 110 metres, i.e. 361 feet.
The actual body of the drone was found at the roof of a ground level outdoor cafeteria, which is next to the base of the tower. As you can see from the pictures, it's puzzling how it's so intact after a free fall of some 100 metres (~330 feet). I haven't yet done any further investigation, except for recovering the microSD card. Some pretty nice photography, although now slightly too expensive.
There's no log file on the card. Not sure if the log was enabled or not.
The pictures are 400-900 K.
http://www.rasbelin.com/images/DJI_0004.jpg
http://www.rasbelin.com/images/DJI_0008.jpg
http://www.rasbelin.com/images/DSC00068.jpg
http://www.rasbelin.com/images/DSC00070.jpg
http://www.rasbelin.com/images/DSC00071.jpg
http://www.rasbelin.com/images/DSC00073.jpg
http://www.rasbelin.com/images/DSC00080.jpg
The drone CSI team, i.e. me, has now concluded based on the iPad flight data and the locations of the items, that the events have unfolded probably somewhat like this:
A) The drone has been flying at about 150 metres and everything has been fine. No noticable winds or any seagulls around. I've taken 8 still pictures, out of which DJI_0008 was the last one.
B) Some 10 seconds after the last shot, as I've intended to continue towards the end of the cape, where the amusement park ends, without any warning the FPV has gone black - no signal.
C) The drone has entered the RTH mode and during that, very soon after it has been initialised, the drone has started to descend at maximum speed (~15 m/s). Possibly either an engine has failed or the firmware has gone bonkers, causing the drone to crash into the observation deck some 50 metres (164 feet) lower.
D) For some reason the battery has ejected and dropped onto the floor.
E) The now powerless drone has possibly bounced from the safety cage and had a free fall down to the ground level. Taken how much G force thrust it gets during a fall that big, it's seriously suprising how intact the device is.
I'm still to compile all details for DJI and I will naturally keep this thread updated about the outcome. However it's pretty obvious that something has gone wrong and I don't see how this can have been a pilot error on my behalf, because the very likely collision has happen after I've lost control of the drone. Also pointing out that the drone has had at least a 15-20 metre (50-65 feet) distance to the tower structures while taking the shots, so it hasn't been on a direct crash course as it has passed by. This can't explain how the drone has crashed much lower than the roof of the tower, which is at about 130 metres (~427 feet), especially since the upper deck of the tower has been between these locations.
Any suggestions what I should do to the remains of the drone? At least the battery seems okay. Will take another battery later on and see if the engines can still idle and if there's any audible hickups.
