Yeah, wise words. I did know the risk of property loss based on earlier stuff I've seen on Youtube and I was cautious about this decision to buy it. However I'd like to take a lesson from this, but it's pretty hard as there's nothing to investigate, except for the app.
So far I've established that I've lost the signal -> I pressed the RTH button on the RC without hesitation -> the mode has changed to GoHome -> the drone has started to descend to 50 metres (my RTH altitude setting) -> then something wierd has happen and it makes a huge loop at least on the map -> mode is P-GPS -> the trail just ends some 20 secs after my loss of signal.
Maybe I should've never pressed RTH, but then again the drone would have done it, too. The video link never came back, so I have no clue about the rest. It's possible that it was a birdstrike or even some gale smashing it into the tower, despite I was at a safe distance.
Will be going out now for a search, but it's probably useless. Any pieces are scattered off-limits to me or in the lake, if that theory still holds.
No, because there has been debate that it shouldn't be done every time you fly time. The notion seems to be that it increases the chance of errors. At this location I would've expected an uneven calibration due to the urban environment. So I calibrated it yesterday in a park.So you did not do a compass recalibration at the start of your flying session?
me 2.I always calibrate at point of launch. Hoping it makes a difference.
Isn't it worth sending the Flight Log into DJI?
I have considered doing that, but compiling the flight data is slow as I only get one image capture at a time from the sharing feature. Haven't seen any smart feature to share it as it is. It's synced online, but I have no clue, if the support can access it?
Plus I need to write a detailed report, so no, haven't yet had the time as I've been busy revisiting the area where it went MIA.
I find it hard to accept that anyone would compare their toy to the loss people must have felt for MH370. Bad analogy for sure.
I read it as a comparison between the seeming disappearance of the two...not equating the feelings of loss. But yeah, bad analogy if others read it as you did.
Always!I always calibrate at point of launch. Hoping it makes a difference.
Is that some sort of radio frequency transmission tower on top of the structure?@JKDSensei: Yes, I did see your post, but didn't want to comment until I got back from my evening search.
I went through the surrounding terrain and even met another Phantom pilot (P2), who whoever wasn't very chatty and seemed to be in a rush to fly his own one. Too bad, because he could have done some very helpful recon for me from 20-30 metres.Curiously I've never before met any other RC pilot here.
Will hopefully hear tomorrow in case it has crashed or against all odds made an emergency landing on the roof at the base of the tower. Until that no news so far. But at least made an attempt to find any scattered pieces of it.
@macsoft: Yes, and I knew the P3P might be flaky, but this definetly goes beyond what I still would've expected.
Based on some analysis we've done on IRC, it seems the drone has probably gone bonkers, because it has accelerated to maximum speed. RTH doesn't happen at max speed. Also the left control is 75% to the left in the last data entry. Hardware failure maybe?
@TAZ: Okay, thanks a bunch! Will try this right away.
To be precise: not the emotions or loss of life, but when you have something vanishing without a trace and against all odds - just like MH370 did. No really trying to be disrespectful to those who perished.
