FC200 camera bricked Phantom 2 Vision
Hello!
I have a problem with my P2V FC200 camera.
I download all the new updates from DJI official page and install them.
All good at the drone but after I update the camera with firmware v1.1.9 it won't power on. There is no power light on camera and won't start.
The problem is like in this video:
I check the 4 pin Jack connection and I see this:
- red wire (+12V)
- black wire (ground)
- green wire (ground)
- white wire (ground)
If anybody know how to bring to life the camera please help me!
Wait for reply.
I'm going to need you to open the top on the phantom, and inspect the CAM port, for burnout, like the picture above. If this is burnt, the camera WILL NOT POWER UP! You will need to replace the phantom mainboard. This is caused by plugging or unplugging the camera with the phantom ON. Please check the port above, and if all is ok, we will move forward!
J Dot
:cool:
Reactions: Mark The Droner
I look at the port and is all ok there. :(
I attach an image.
Do you have a multi-meter?
Set to DC volts, check between RED and BLACK leads circled in pic below ( with bird ON ) see f you get voltage?
If we have power here, then we will move on!
J Dot
:cool:
Ok,
With power to phantom OFF, unplug the large white wire going to the camera,
Once unhooked, carefully meter between these two leads, and look for volts.
See if you have volts here, then we will move on.
J Dot
:cool:
( ps, turn bird off before plugging camera back in. )
Do you have any ideea how to install the firmware v1.08? I found the 1.08 version in forum but I think the DJI remove the package installer front server.
The only version I could install îs 3.14. I think this could be a problem to the camera.
Is there any way to install the firmware offline?
Thank you!
J Dot, thank you for your support!
I decided to give up for repair and sell the drone.
I want to buy a Phantom 1. I think is cheaper for maintenance.
Thanks again!
P2V have black screen and have a line on some brand new in box FC200 - if using android app 1.0.61 and install new camera will this solve the black screen issue - it’s my understanding that the board that’s bricked is in the camera - any help is appreciated.
