I had the same! Normally it’s corrosion in the electro engines not being used for a while and stored in a humid place.After two months without any fly, the faboulus Error ESC appears and nothing found to fix it.
Someone has the solution ?
P3P
Thanks!
Um, not sure about that. There is nothing in these motors where corrosion can get, the coils should be well insulated so are waterproof, you can actually run them under water! They have no commutators like the old DC motors......I had the same! Normally it’s corrosion in the electro engines not being used for a while and stored in a humid place.
