ESC Beep?
Updated the firmware to 1.05.0300 and I swear I've never seen this setting in GO 4 before - ESC Beep.
In fact it makes the drone beep.
What's the use aside from a locator beacon? Why call it ESC Beep?
It’s probably called ESC beep as the sound comes from the motors following an audio signal being generated by the ESC.... what else could the call it?
Hi it's just the same when first turned on esc (electronic speed controller)Yeh mainly to help locate if goes in brushy type bush's or long grass,,Yeh I was playing with my beeping today aswell,,it used to be located in the lost my drone part but never worked,at least now it works,,if you not further than 50ft give or take on wind noise etc
Reactions: Brojon
Nwbailey
