We’ll break things down into two categories: offline editing — and limited online work — and online editing, meaning a good entry level for multiple 4K streams, VFX and color grading at or near real-time. These specs are good for both PC and Mac since there isn’t much difference in the hardware.
CPU: Processor
Offline Editing: Intel Core i7 2.3GHz four-core
Online Editing: Dual Intel Xeon 2GHz six-core
Now that most editing software supports GPU rendering, CPU power is less important than it was in the past. Note: AMD processors are not listed because of the lack of support for PCIe 3.0 in most AMD motherboards, which hinders the performance of the latest GPUs. AMD processors can still be used, but should be paired with a more powerful GPU.
GPU: Video Card
Offline Editing: NVIDIA GeForce GT 750M
Online Editing: Dual NVIDIA GeForce GTX 760M
Always check the compatibility of your editing software with your video card to ensure that GPU rendering and multiple GPUs are supported. A comparable, compatible AMD or NVIDIA GPU can be used. The GeForce cards listed above are a baseline. While many GPUs have greater video rendering power than system CPUs and RAM, remember GPUs need enough power to drive your system display monitors in addition to rendering video.
When monitoring in 4K, you can improve system performance by taking some of the workload off your GPU using a RED ROCKET card, Blackmagic Design’s
DeckLink 4K Extreme or
Matrox's Mojito 4K. It's important to note that with the developments of REDCINE-X PRO, you can now use GPU rendering instead of needing a Red Rocket card for accelerated transcoding of R3D footage.
RAM – Memory
Offline Editing: 8GB RAM
Online Editing: 32GB RAM
RAM is relatively cheap so don't skimp here. Remember, when you're running RAM intensive programs like Adobe’s
Photoshop or
After Effects concurrently with your editing software, your RAM needs may increase.
Storage at least a 500 gig HD. Is best at minimum
