Using a LiHv 6600 with no camera I have gone out to 66 K feet and back landing with 1%. A friend of mine strapped on 2X4000 Lipos with no camera and got out to 70 K and back...It would seem splitting the LiHV 8000 would have better results?
If your splitting a 6600, 80mm pvc shrink tube is perfect!Thanks for that info PRO...I already ordered the longer balancing leads,12 gauge wire, some more xt60 connectors (in case I want to extend the power leads) ,and some 50mm and 100mm shrink tube (hope one of those sizes work for me)
https://www.amazon.com/gp/product/B01EFIRDUW/ref=od_aui_detailpages00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B01CMCFZ7G/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B01ETROGP4/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Shrink Tube
I look forward to watching your video....
Hey Chazz, ebay has the 80mm cheap. If you gave questions or need help while splitting the packs, shoot me a pmI know this has nothing to do with anything but I received my package (hobby king shrink tube) from Hong Kong in 2 days from DHL and my amazon order was shipped from one state away and will be here tomorrow...Yes one was free and the other cost more then product itself but holy cow 2 days from Hong Kong!
By the way 100mm is way to big don't even know what i was thinking...50mm will work...Wish they had 65 or 75mm...I know what ill be doing Saturday...Hopefully not setting my house on fire in the process![]()
Yeah I guess it is...If the bird goes it goes I don't fly over populated areas...Somewhere around 10 flights with it so far...I'll let everyone know If or when it happens...
Being Procharged97 said 80 will work for a 6600 that will also work for 8000...They are not much different in size... The split battery will be 50mm high and 25mm wide...I'm not sure if all shrink tubing is measured by diameter or the size when its flat but mine is 50mm diameter and it will work but maybe 80 would be better...What size PVC shrink would be used if splitting a lihv 8000? thanks
which bird are you flying with ?
and anyone else like to add curious who is using P4's, P3's
When are you going to post the video? I'm looking forward to it. Thanks.Not hard just be careful, for MS batts cut the shrink wrap off only!! Then remove the tape and foam over the top covering wires, theres more tape and kapton tape, remove that as well. Each cell pack is stuck together with small squares of strong 2 sided thin foam tape. Separate down the center. You will need to add length to the bslance plug wires and the one wire that will connect needs to be 8". I made a video doing tthe whole process and will try to post it soon
Sent from my SM-G900V using PhantomPilots mobile app
can someone with a 6600 split post a pic of it mounted to the bird? I would like to see how its mounted to the legs and the path of the leads to the battery...
Why split it though?? Balance/weight? Seems leaving single would give best results.Using a LiHv 6600 with no camera I have gone out to 66 K feet and back landing with 1%. A friend of mine strapped on 2X4000 Lipos with no camera and got out to 70 K and back...It would seem splitting the LiHV 8000 would have better results?
I wonder how it can weight only 525 with all this leads hanging everywhere ?! Mine non split is already 520 g ...
Yes it's good, light and I can fly 32 mn with it, landed at 9%
I concur. Tried 2 of these MS4000 batteries today and got 31 mins with 17-18% remaining when landed. Not bad at all considering it's nearly 100 grams lighter.
did you buy the lihv version or standard lipo?
I'm still waiting for my 4000mah MS lihv to be delivered been sitting at a depot not far from me the past 3 days.. Waiting until australia post decide to delivery it to me.
