Dropping from the sky
Hi
Recently had a P3 Advanced and yesterday happily flying and then before I knew it the thing just crashed to the ground !!!
Checked the logs and I saw the following:
7273 [M.Start]REQ_RC_NORMAL
7273 [Ctrl<2>] REQ_RC_COMMAND ENGINE_START ctrl_engine_start
7274 [IOC.CL ] 92.9 Degree
7274 [TO.ALT ] 108.363075
7274 52.5607255 -2.0923711 128.36 Home Point
7374 [Ctrl<2>] REQ_RC_COMMAND ASST_TAKEOFF_HOLD ctrl_asst_takeoff
[2A]App Cmd 2
8116 [Ctrl<7>] REQ_APP_WM610 AUTO_LANDING_HOLD ctrl_auto_landing
8142 [M. Stop]ACT.landing
8142 Motor Start 1 Total 17.38
8142 CTRL reset all by motor stopped
8142 [ACT.msg] ACT_AUTO_LANDING can't exec auto-landing while motor off
8143 [Ctrl<1>] REQ_RC_NORMAL ATTI_HOLD ctrl_gps_atti
8834 [M.Start]REQ_RC_NORMAL
8834 [Ctrl<2>] REQ_RC_COMMAND ENGINE_START ctrl_engine_start
8835 [TO.ALT ] 108.368111
8835 52.5607190 -2.0923668 128.37 Home Point
8935 [Ctrl<2>] REQ_RC_COMMAND ASST_TAKEOFF_HOLD ctrl_asst_takeoff
9701 CTRL reset all by assisted takeoff finish
9702 [Ctrl<1>] REQ_RC_NORMAL ATTI_HOLD ctrl_gps_atti
9821 Eeprom write offset:328
it is the 3 lines in red that concern me ....
Anyone else experienced the motors just shutting off ???
I know for a fact I didnt do anything on the RC .. and I suspect if I did it would be prefixed with RC_COMMAND ... so it looks like the unit itself just shutdown ??
Not having much luck with DJI support at this stage .
Thanks
My standard just dropped from 30 meters on RTH mode. I found only three props on so I assume one motor just shut down and flipped the prop. Sending it Back for warranty. If you can't trust the thing flying in auto we have a problem
That's possible. It's also possible that the prop was damaged. If the hub is cracked and/or the hub threads are stripped, the prop will spin off when the Phantom brakes.
