Drone ID GPS - Electronic identification module for drone
France, Essonne
hello,
I am in FRANCE, and with the law french, I must to have a " Electronic identification module for my drone"; I found this module , on "Drone ID GPS - Module d'identification electronique pour drone | Airbot Systems"
Do you know how I can connect it inside the P4 Pro, it needs a 5volts connection.
thanks for your help
Patrick
I am confused, doesn't Ph4 have DJIs DroneID protocol? The one which they sneaked into firmware without telling anyone?
Do you use old firmware, or is the DJIs protocol not compliant with French law?
Hello, the P4 Pro does not have the built-in tag, only from the P4 Pro V2 and my firmware is up to date.
I see. So this means the DJIs own DroneID was only introduced in order for Aeroscope to work, and it is not compatible with the DroneID protocol required by the new law.
Jerry P
