500m is the max altitude the DJI GO app will allow.120m up is the max
Yes exactly. So if following the rules in the video about antennas, how much more space can wifi signal booster give me?500m is the max altitude the DJI GO app will allow.
Per DJI's specs, you can reach 1,000m (500m CE) under the most ideal conditions. If you're in a wide open area with absolutely no interference, you might even be able to reach beyond that.how much more space can wifi signal booster give me?
So in the same park, it might not give me better results, am i correct?Per DJI's specs, you can reach 1,000m (500m CE) under the most ideal conditions. If you're in a wide open area with absolutely no interference, you might even be able to reach beyond that.
Yep. That's the default maximum altitude. You must change it in the DJI GO app while your remote controller is connected to your Phantom.btw on that link it does say that maximum altitude is 120m...so its true?
I see. I thought it wasnt adjustable.Yep. That's the default maximum altitude. You must change it in the DJI GO app while your remote controller is connected to your Phantom.
The Pro/Advanced specs also show the same software limitation. They aren't limited to 120m either though.IYou can only change it in the app because of the advance and pro model.
I am in California and I had my P3S up to 850 feet just today.No, Ima Texas. I have since installed the DBS mod, but haven't tested yet
