You need to center that board over the over the plastic standoffs then either cut black fiber shield off the the cable or slide over the connector as i see it has been modified. Another pilot had that shielding on his P2 and it came in contact with components on the board and shorted out the board.
I think what he means is that you need to put the modded bit in the middle of the board. It's to much on one side causing weight distribution issues
Neon Euc
thank you JasonOk now the board is centered but you still need to remove that black covering on the cable as it is not necessary and can cause a short as in the photo i sent.
If that video hover flight outside was yours video you never had 6 or more satellites before lifted off by the flashing green and 2 red LEDs on the rear arms.
thank you Jason
yes that was my first ever flight outside, was testing so didnt take it far. i have alot of trees around me so that was probably why the gps signal was poor.
i thought you said i could put the cable to the side so it wont touch any components?
thank you, i will remove the black covering now.That covering is not needed and was not used for long by DJI besides the wires are coded and the shielding is not needed.
Trying to get a good GPS signal 6 or more under a canopy of trees can be difficult just like when you're in the house. To see how difficult it can be to achieve 6 or more satellites put the P2 on the wall that surround the lawn on the patio so you have good view rear LEDs. When the LEDs began to slowly flash green cover the top of the P2 with your hand to see what happens with the LEDs.
i have now removed the black coverTrying to get a good GPS signal 6 or more under a canopy of trees can be difficult just like when you're in the house. To see how difficult it can be to achieve 6 or more satellites put the P2 on the wall that surround the lawn on the patio so you have good view rear LEDs. When the LEDs began to slowly flash green cover the top of the P2 with your hand to see what happens with the LEDs.
thank you very much for all your help.Well that looks better now reassemble it and have fun.
can you get the bit inside the shell where you put the screw in on its own?Well that looks better now reassemble it and have fun.
