do these files belong on sd card?
mabank TX
I was just wondering if these files are supposed to be on the sd card at all times to keep drone operating? I kw the dcim file is where the pictures are stored just wasn't sure if I should delete these other 3 files. They are on the card now and the drone flies normally so no need to fix what aint broken, but I am curious if they are needed for flight. Thanks for your advice.
Your Phantom doesn't need any files on the SD card to fly OK.
It flies perfectly well with no card at all.
You can safely format your SD card before each flight and start with a completely blank card.
Reactions: ROD PAINTER
Ok thank you, I thought that I could remove them and use a blank card from what I have read here and seen in the videos but just wanted to make sure before making a mistake. thank you again for your help!
most
