DJI Phantom won't lift off with gopro.
Hello
the phantom took a stumble, I re-calibrated, everything seemed fine, lift off without gopro is flawless,
when I attached the gopro, it will tip and crash, if I help it and hold the phantom up upon take off it will fly perfect. : (
it will also land soft.
But it's frustrating for it not to lift off correctly.
Any advice its much appreciated.
Thank you
If you replaced the props, check their balance...the only time I couldn't get mine off the ground without tipping was when I had on some poorly balanced props. After a little sanding it worked just fine.
ODIN Reviews
