DJI Phantom strange noise and Vibration in Idle speed
Geldrop
I already change the props,and I sheck out all screws.
Nevver had an crash, and about 6 flying hours.
Anyone has an clue what this problem can be? tmr i go back to my dealer with this drone.
01-08 went to the dealer it was yust the airflow below the drone, testet it on the top of an rabit kage and the vibrition was gone:)
What problem exactly???
You cannot evaluate such things when idling on the ground or strapped down, or no props.
The FC (IMU) is sensing the physical change you are creating in one or more axis and adjusting the motor RPMs to achieve stability.
It's functioning normally.
Go fly and stop worrying.
Re-check all your calibrations especially the IMU and if all good test flight low altitude and short range. Test the stability and hovering. Afterwards you should get a good feal for the proper operation of the craft. Test after your satisfied the home lock and fail safe if all goes well.. She's good to go.
Nachobriefs
