Folks,
Not sure if you tried to set the XYZ values in the "Mounting Location" tab of the Assistant Software, but those numbers keep resetting to 0 after power cycling the quad.
IMU (X/Y/Z) : the values reset to 0 after hitting enter
GPS (X/Y/Z) : Seems to be stored in a volatile memory and they hold until you power cycle the quad.
I believe the center of gravity has changed since adding a tarot2d and a gopro Hero 4, I also pushed the gimbal forward to avoid the propellers. I need to set the Z axis to -2 and the X to 1, but it's driving me crazy as it won't save.
I wonder if DJI assume that we don't change the CoG or it's a simple bug in their software.
Please advice.
Thanks!
Please advice.
Thanks!
