DJI P4P Battery case cracks
All three of my batteries have the dreaded crack near the lights on the front face of the battery casing. Does anyone know if just the case can be replaced and if so, where you can buy the case?
Reactions: Jim Canada
Also interested in replies
I have these on all four batteries (two separate batches) - back to the same old DJI problem of using 'recycled yoghurt pots' to make drones!
It does look as if the top area can be swapped out, but where can you get that part and how ££. I've heard that some people 'plasweld' the crack area.
added -> FWIW the actual latch area is solid and works on mine, this is a cosmetic thing
The cracks near the lights are no big deal. They are caused by the pressure of the battery latch springs on the inside of the front cover. Unless the cracks got so bad that some of the plastic broke away and let the spring end come through, which has never happened in my experience, you can just ignore the cracks and keep on flying.
akos9703
