I have the same strap. I am 5' 9" and I have the straps adjusted so the remote hangs right at the top edge of my belt. I also replaced the tablet mount with a metal one that has a second hole farther up. The remote balances nicely and hand launching is much easier.I recently bought this neck strap...
https://www.amazon.com/gp/product/B00ZZPYIVW/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
The problem is it hangs to low. Should the neck strap support the weight of the remote while flying or just be there to catch the remote if you drop it?
Thanks!
I hope that you will take a moment to examine your misuse of this awesome design, and correct it's ultimate wearing length to your comfort approval & hopefully utter amazement... HahaThanks, It's a good video, and I've already watched it, but facts are facts. I now use one like I've seen DJI reps use in videos. Works great.
Hahaha, oh no, not you too!! When ever you weathered pilots buy something RC related, why not investigate the item first? Be aware of the concept, how it works, & why the heck you bought it in the first pace. hahaha
The more of you guys who profess to finally figuring this Inspire 1 harness out, it brings myself all the more, cheer. Hehe
Watch the video? Yours may be defective, but if you send it to me to test and relate the info back, we can know for sure... ;-)
Yea, these straps are a bit of a hassle to understand, but once you wear it correctly, you will then realze how awesome they are.
RedHotPoker
I have it, but prefer a tray instead. The problem for me is that it conceals the RC LED which lets you determine lost connection. I don't like having to pull it out of the holder and away from my body to check the LED when I lose FPV. Also, the aluminum holder just isn't secure enough to support the RC properly like a tray does. It also hangs much lower than I would like it to, with no way I can discern to shorten it further. Get a tray instead. You'll be much happier in the long run.I never saw the usefulness of a harness rig you have to climb into just to have the remote still dangle unbalanced. And when you deal with summer shirts and then winter coats, adjusting can be tedious especially in the transitional seasons where you wear different weight coats accordingly. Heck, I often wear a light coat in the nightime summer heat just to avoid being eaten alive by mosquitos. Too much adjusting. Practically speaking, you need to put a strap over your neck and fly, not fiddle with a harness as part of a routine. There's enough preflight routine with these birds.
However, this one caught my eye because I don't like the rc dangling unbalanced on the end of a hook.
Zero Gravity Remote Controller Harness System for DJI Phantom 1/2/3 and Inspire 1 Remote Controller
My only concern is that I absolutely prefer my rc with ipad air2 to sit higher on my torso. I cannot fly with my rc low slung at my waist. How anyone can look that far down and fly the sticks that far down is beyond me, not to mention looking up and down and the neck strain of that. My remote on my strap lands on my upper stomach so it puts my ipad nicely in my face without looking at the ground and the sticks at a comfortable position. The zero gravity doesn't look like it accommodates high position. Also it doesn't look to unclip from the harness. I would prefer the rc sleeve stay on the remote full time and easily clip on to the harness. Anyone have the zero gravity for further details about it?
Thanks a bunch for that. Appreciate it.I have it, but prefer a tray instead. The problem for me is that it conceals the RC LED which lets you determine lost connection. I don't like having to pull it out of the holder and away from my body to check the LED when I lose FPV. Also, the aluminum holder just isn't secure enough to support the RC properly like a tray does. It also hangs much lower than I would like it to, with no way I can discern to shorten it further. Get a tray instead. You'll be much happier in the long run.
Which harness style neck strap are you using? The Zero Gravity one, or a different one? I have, instead, been using a harness style tray, and it is, indeed, very comfortable, and its support from underneath keeps the transmitter from separating at the screws, due to to the extra weight of the booster amps and their battery, taped securely to the bottom of the transmitter, pulling away from the neck strap connector on the top, when otherwise suspended without the tray, when you need both hands to attach and detach the external battery connectors.Forever young..
Once I had my neck strap adjusted, which took all of 3 1/2 short minutes, it was at my perfect length to fly, in a very comfortable position, if the RC hangs loose, & never a strain on my neck. All in all, an awesome combination of security, comfort and style. Several other pilots at ERCHA fly with this harness style of support and we couldn't be any happier.
The fact that it has four straps to adjust ultimate length makes it convenient to size just right. A perfect fit is only a couple of strap tabs pull or push, away. Hahaha
Make mine a double. ;-)
Time to pack up the flight kit, and head over to a convenient park, to play RC pilot.
Alert ain't the word, my boy, the term is aggressively-eager.
RedHotPoker
Thanks for the tips! I have that one already coming from B&H, so now I'll know how to set it up properly when it arrives!I bought the Inspire 1 neck strap and like this design a lot. This is a style which completely removes any weight from my RC away from the upper spine, transferring it to my shoulders and around my chest, in a most comfortable and securely held fashion. But it has to be adjusted so. There are two rubber emblems on this. And depending where you wear the larger rear one, the difference will be where the weight is mostly distributed.
With the patch higher up, the weight is raised towards the upper back/lower neck. Sliding this rubber strap separator lower down, transfers the majority of weight to shoulders mid back and chest.
A tray would be awesome too, but too much trouble to stash and carry, as my @dji hardshell backpack is already full. So too, as well, is my SpYder RS-S "frunk". I be "Rollin' dirty" ;-)
I can appreciate & respect any style others desire and prefer to dangle the Tx from...
Heck, A Wayne Gretzky hockey lace. . . Hahaha
RedHotPoker
