DJI has released the new firmware v3.08 for Phantom 2 series
Re: DJI has released the new firmware v3.08 for Phantom 2 se
Geert said:
saao said:
hey guys tried downloading the new assistant and it just crashes while opening on my mac anybody else facing the same issue?
Worked fine for me on my Macbook.
Geert./.
a couple of days ago i tired downloading the 3.2 assistant and the same thing happened it should open despite if its connected to the phantom or not rite?
saao said:
Geert./.
yes
do a repair of permissions.
I called UAV-OUTLET about the upgraded parts & cost. I got a recording in which I left a message. Have to wait for the call back now. They're prolly going through their shipment of these new parts. :)
There is a new assistant download 3.4
This is the new manual for the firmware, do they not have the wording mixed up on the battery levels?
Did this fix the no FPV (telemetry working) on P2V+ that broke on some with the last iteration of the app?
Kinda weird that the Vision Assistant 3.2 info tab says no updates available, and you have to actually go to the website and download 3.4. Then you have both versions and have to manually uninstall 3.2!
Where are all these battery features???
Happyflyer said:
Yippie! Camera tilt for P2V!
....and some other things look nice.
great, but what about camera tilt for the P2V+??? is the little lever on the back of the tranny functional yet???
EDIT, apparently yes according to the P2V+ section. :oops:
I'm also wondering?
Also, The Battery History info on the app tells me this battery is not supported .....
HUhhh it's a DJI original battery!
Some of the features might be good but the new firmware stops the Limefuel battery from working (maybe others too?)
At work so I can't get the manual just yet.. but how does the RTH altitude feature work ??
Also.. to upgrade.. I uninstall Assistant 3.2 and drivers, and download 3.4... then connect Phantom like normal and it will tell me 3.08 is available ?
Not sure If I should upgrade or see how it goes for the next few days with you guys :p Normally I like to run the latest and test... but $1800 :p
The Limefuel Battery doesn't work on 3.08? Of course it doesn't - I ordered one just last night....
No need to uninstall 3.2 and drivers. Just install 3.4 etc.. (you can uninstall 3.2 later to save disk space, but if you keep it, you can (?) revert back to previous firmware version.)
Are you referring to the warning LF posted earlier?
I read it to mean that the 'battery firmware' v2.6 is the non-compatable file not the MC v3.08.
Just done the upgrade but battery firmware is still at v2. How do I do the battery upgrade to v2.6? I assume this why the app is currently telling me the battery level is not supported when I access the new battery history tab... Anyone able to help?
I had to use the Assistant 3.2 software to upgrade each battery to v2.6 as the 3.4 version didn't provide the option to upgrade the battery.
rockymountaincaptures
