DJI GO4 APP On Ipad Pro has Freezing stills
During rapid image capture the display freezes although the camera continues to work. Is there a way to resize the image or prevent freezing?
I had same problem and found out my computer could not process that high level video. I switched to my laptop and the videos worked with no freezing.
Good luck
Jim
WA5TEF
There could be many reasons for freezing the display during the flights. Start viewing with the minimum transmission rate. That would give you a hint for the source of issue.
The issue happens during rapid capture. Timer and manual, so I agree the write buffer maybe is the issue. It is only with the go app. I use the planning app without issue. Its capture rate is half that of the other , go4.
Is there a reset to the go4 when video freezes?
I have been forced to land and restart at this point.
Don carlos
