dji go 4 does not update gps real time, what can it be?
Guys, I have a problem that I'm breaking my head and I can not solve.
I bought a mini ipad 4 for the phantom, installed the dji go 4, put the mobile phone chip in google maps, and in litchi it recognizes the gps of the tablet perfectly.
I fly shows where the drone is and if I get out of my position the round blue gps ball moves, all in real time right on.
But in the dji go 4, when I open it shows the position in which I have an arrow as if it were the direction I am looking and it is locked, I can walk blocks and blocks that the blue ball does not move, does not move, someone Have you been through this?
The dji go 4 on the iphone 7 runs the gps normally and perfectly, but on the ipad mini 4 not, and the ipad mini 4 on the litchi and maps works, only on the dji go 4 not, if anyone knows of a light please
If I am reading your post correctly the "blue ball" you are referencing is the tablet or phone GPS location. Not the aircraft.
Yes that's right
it takes the correct position when I open the program, but it does not move, and on the iphone 7 when I leave the place it moves.
Defect on the tablet is not because in the litchi it moves and in the map of the tablet too, only in the dji go 4 that does not.
Check your settings in GO. I fly exclusively with Litchi and only use GO for certain maintenance that Litchi does not have. Also, it is the Pre-P4 GO app, so I can not answer your question directly as to the setting locations in GO4....maybe @msinger can answer that better than myself.
What exactly does this mean?
Does the blue ball move when using the map apps on your iPad Mini 4?
Reactions: bronis
[/QUOTE]
Thank you for trying to help people.
So the blue ball in google maps and in the litchi moves perfectly, I leave the place it moves and shows exactly where I am, but in dji go it gets stuck, I will send a print here so you have an idea.
what happens is this, the blue ball is pointing in a direction and does not leave there, I already tested today in the street, flying the drone, and I went by car walked several blocks he stays in the fixed place does not leave.
In the litchi I did the test went by car walking with the drone, and the blue ball in the litchi was marking exactly the position that I was going.
112690
112691
112692
Make sure DJI GO has permission to use your location. You can find that setting in the following section of the iOS Settings:
112693
yes this one, I tried it during the use and already I left also always, always of the same thing.
I have already uninstalled the dji go 4, rebooted the tablet, installed again, and continue, I do not know what can be happening, just in the rest of the rest everything works perfectly, maps and litchi.
I had the same problem but I found a solution. I have to put litchi to sleep, while running go 4 on my mini 4. I don't have to do that on my full-size iPad only my Mini 4. Just a thought, good luck.
Falcoray
