DJI fc40 RC question
Hello,
Recently the antenna on my RC broke while storing it. I bought a new antenna and installed it. However, the connector broke of the printing plate. Long story short, after some soldering i ended up messing up the whole printing plate.
After some searching, i found a secondhand RC controller on Ebay. My question: will this secondhand RC work on my own FC40 drone?
Grtz
It should if it's 5.8 ghz.
Been awhile since my P1 but there should be a button/light on bottom of drone.
Push in until led lights flash on drone and then turn on remote
led lights should then stop flashing
Okay, thanks!
Yesterday a new (secondhand) PVT581 controller arrived. I removed the 5,8G VT plate with the antenna attached to it and put it in my own RC (since the RC i ordered looked a little messy). However, when i tried to put the DJI on, nothing happened. Also the LED is flickering : 4 times red (fast) 1 second pause, 4 times red and so on. Which means (if i'm not mistaking) that the RC does not connect to the drone itself.
Does annyone have a solution for this issue?
Scav8tor
